VGN AR11B HELP IMPOSSBILE TO RE INSTALL DEFAULT SYSTEM / BLEU SCREEN
RBONNIN
Hi alls,
I bought 1 month ago a VGNAR11B. I let it on during the night and in the morning i find the famous blue screen of windows.
I try to restart the computer, impossible to reboot....
I took my DVD system recovery.... and i choose compte re installation... I try hardware checking nothing is wrong...
And a 15% the blue screen come again, and stop installation...
What is the problem ?
Thanks for your Help
Hi RBONNIN and welcome to the Club.
Can you get into the System BIOS?
1. Turn on your VAIO.
2. When you see the Sony logo, press F2 several times.
3. You will get the BIOS Setup Utility window.
4. Press F9 to get default values and then press ENTER to confirm.
5. Press F10 to save changes and exit and then press ENTER to confirm.
6. You have restored the default values and your VAIO will now restart.
Now try a Recovery.
:wink:
