VGN-AR11M audio problem...
lourens
I have problem using any kind of software for listen my music, in every format. The problem is a very bad sound quality, like scratchs on ancients disks. The very strange fact is that if I use Windows Media Player I've no problem. I think this is not normal. I've this problem since the first day I've purchased the notebook. :slight_frown:
4 REPLIES 4
out-of-space
hi, lourens.
i had the problem while playing games. problem was the autostart function of the sonic stage software - it automatically picked 5.1 sound instead of stereo. disable that, maybe it will help.
cheers
o-o-s
peter4654
That's correct, Lourens. You'll probably find that you have sound problems with Quicktime as well. Just remove audio from the startup folder and restart the computer.
mmbecks7
How do u do this???
Dekesh
go to start/all programs/startup and right click on audio filter and then chose delete. it wont startup when u log into windows next time
