Hello!
After reinstallind the windows (recovery dvd was created) i cant install drivers for sound. Drivers that I have on HDD want Microsoft Bus Driver. Where I can find it?
Drivers for Modem are not installed, windows says, that its not correct for this device type.
Using WinXP SP1.
What I need to download to fix the problem?
Big thanks!
If you install a other Windows, then you need all drivers.
You can find the driver and utility package on VAIO-Link.
Sorry, but I cant find it, there is only Preinstalled drivers, that doesn't work.
Thaks
Hallo,
the preinstalled drivers must work with win xp,
xp home or xp pro drivers are not difficult
maybe update sp2 is the answer
Hello!
Using WinXP SP1.
Big thanks!
That's true. And some drivers are not in a Windows Installer package. Then you must rightclick on the .inf file and click install.
So I have one problem:
Functional keys dont work.
What driver or/and utilitu I need to install?
P.s. I cant find anything useful about this question in viao-link.
