VGN-S3HP - Matshita UJ-822Da v1.0 optical drive problem
profile.country.ES.title
pepe10000
Hi everybody,
I bought my VGN-S3HP three months ago and now my optical drive (Matshita UJ-822Da 1.0) cannot read original DVD films (8.5GB). Basically, it doesn't recognise that DVD disks.
I did all this:
1) System Restore to a Restore point where the Vaio was working fine.
2) A Clean Boot of Windows, to see if there are any processes or programs which are blocking the access to the DVD.
3) I checked in the Device Manager if there are no exclamation mark or question mark next to the drive, but there is no problem there.
4) I also reinstalled the driver.
5) Finally, I did a system recovery using the VAIO Recovery Tool to left the notebook at same state when I bought it, and nothing happened; the optical drive was working same wrong than before the system recovery.
And my results were these:
1) None of methods worked.
2) My results are these:
a) The optical drive can read CD's (original and CD-R) and write CD's too. Although, sometimes, the optical drive can detect the original music CDs, it doesn't read them in a good way; it has problems and it freezes a bit whem I jump from one song to another one.
b) The optical drive can read DVD's (only DVD-R and DVD-RW) and write DVD-R/RW too. Moreover, sometimes the optical drive doesn't recognise the DVD-R and I have to expulse and reintroduce the DVD-R (4.7GB) again to achieve that the system recognise it. It seems to work well with DVD-Rs from Sony, LG, Verbatim and TDK, but gives me problems with the BASF-EMTEC mark, recorded before.
c) The optical drive NEVER can read original DVD films, now; and I think that the problem could be that these are dual layer DVDs (8.5GB) and the optical drive has problems to read them; although it has sometimes problems to read single layer recorded DVD-R (4.7GB) too now, like I told you above.
Then, do you think that this is a Hardware problem?
Could be a firmware problem of the optical drive (MATSHITA UJ-822Da v1.0)?
Could you help me, please?
Thank you very much floks.
14 REPLIES 14
kee-lo_
I would arrange a pickup with VAIO-Link.com
pepe10000
Hi Kee-Lo,
What do you mean?
Do you mean that I should send my notebook for repairing?
Regards,
Torakaru.
tonybeard
Buy a good quality DVD reader cleaner CD and reinstall the drivers. Otherwise the 'Lo is right you will need to start a case with Vaio Link and get it repaired. To be honest with you. I have the same exact Matshitty and I have had no trouble but so many here at CV have that it is only a matter of time. My advice is to upgrade to anything but a Matshita (Panasonic) optical drive. Maybe to the new Dual layer DVD RW drives I think they Toshiba.
pepe10000
Hi TonyBeard,
Do you think that a DVD reader cleaner CD will help me really?
Moreover, like you can see in my post, the problem is very strange, because I cannot understand why the optical drive can read and write DVD-R (4.7GB) but it cannot read original DVD films (8.5GB).
Do you know if is posible an firmware update?
Finally, how I can upgrade my optical drive? I think that it is customized for my VAIO laptop, should I send it to SOny for that kind of update? Is that possible?
Sorry by all my questions and thank you very much in advance
kee-lo_
Hi Kee-Lo,
What do you mean?
Regards,
Torakaru.
You go to vaio-link.com
and set up a case
they'll pick it up via DHL, fix it and return it to you within 10 working days
ant1uk
Hi Kee-Lo,
thats if your lucky!!! only joking sometimes they come good first time
tonybeard
Honesty it sounds crazy but the cleaner CD has worked for others here at CV but I have only put it to you as a last resort seeing as you have covered all bases already. Also incase it is a codec problem try this alrounder packK-Lite Codec Pack and Power DVD
pepe10000
Hi TonyBeard,
I was using the K-Lite Codec Pack already; and moreover, I bought a good DVD cleaner yesterday and after use it nothing happened. I continue having the same problem. By the way, thank you very much by all your advices, really.
By other side, I send my case several days ago (5 exactly), and I have bot any new from the people of E-support at Vaio-Link; do you know how much time they need to read my case and answer it, please?
Thank you again.
Torakaru.
pepe10000
Moreover, has anyone another idea to how can I solve my problem, please?
Thanks a lot.
