partition magic 8?
I have 30gigs free on my app drive (C) and 8 left on my data drive(D). If I use PM8, will simply sliding the bar across so I have 10gigs free on C cause any problems with the fingerprint software or the Safe data area?
I'd perosnally not do it, had troubles before with PM, not keen on it.
Aproach with caution.
There is no such thing as a safe on the fly partitioning program. You should always make sure that you have a good backup set and that you have working recovery disks before you try to change partition sizes.
I generally use Paragon Partition Manager and have had good results in most circumstances.
i used PM8 and it was seamless, but did take an hour to complete
i think it's best to backup now though
