windows 10
Himski
windows 10
i want to put windows 10 on my vgn-ns20e is it possible has it got the capacity
Hi Himski and welcome.
Unless someone here has actually tried it on your model it will be a matter of backing everything up and giving Windows 10 a shot!
What OS are you running at the moment? I guess your Vaio came with 32-bit Vista installed - have you already updated this?
Have you increased the RAM to 4GB?
Checking if all the hardware is compatible may be a problem. I have tried to check it the T3400 processor will work but the results are mixed. Fortunately 32 and 64-bit driver support is still available for download on the Sony Support website here:
https://www.sony.co.uk/electronics/support/laptop-pc-vgn-series/vgn-ns20e?downloads-num=33
Good Luck but as I said, unless someone here has tried it, you will be in trial and error mode!
