Bought a new Sony VAIO which is wireless. Please anyone help.... coming up as Wireless Network connection Not connected. Do i need to use a usb flash drive to set up this network or is it done automatically through your computer. Thanks in advance,sorry if it doesn't make sense.
Hi jay_gob thanks for the reply but still no luck iv'e tried evrything and i get as far as put your network key in but don't know where this is i know it is something simple but i'm baffled,thanks again chocolate
We really need to know the make and the model of the wireless router you are trying to connect to.
They are all a little different!!
i had the same problem but i contacted my broadband provider (orange) and they guided me through the whole process.
