One handed mode
Lutkis
One handed mode
Does anyone else have a problem with this?
It doesn't do anything when I double tap the home button and when I select it from the side sense menu it says it's "not available at this moment".
21 REPLIES 21
Jonas
Master
Hi @VRZ78,
Oh, I understand that isn't optimal. Slightly_frowning_Face
I'm not sure if this the limitation will be removed, but I will gladly forward your feedback, but I can't make any promises that this will be changed.
Have a nice weekend!
MythicSuns
For anyone else reading this I advise going to settings>accessibility and then turning off any service and then trying one handed mode to see if it works with that service turned off. I did this and much like the OP i discovered that Macrodroid was blocking it, but specifically the Macrodroid UI interaction service.
