5.433.01 firmware
romeo_kii
5.433.01 firmware
hi all, after applying this latest firmware, my tv has become alot dimmer , after factory reset still the same , enhanced format hdr colours are not the same as the were in previous firmware v5.417, hdr luks dim and fuzzy,, please any way to downgrade back? im gutted , never should have updated!! this new firmware does not
  • Improves the user experience (UX) of the "Enhanced format - HDMI signal format" setting as it states, its horrible
17 REPLIES 17
profile.country.SE.title
hitta_jonte
What firmware version is the latest?
profile.country.NL.title
Lezzzz
5.433, same as topic name.
romeo_kii
morning, do you mean motionflow is still on after disabling it? are you watching movie through netflix or usb or bluray? ill try a movie now , see if i can see what is goin on loll edit.. just watched avatar , smoothing is off after disabling motionflow and film mode , maybe you have to factory reset your tv
Lezzzz
Yes in menu it is disabled but visually it looks like it’s enabled: over the top smooth motions. Like mentioned here https://www.cnet.com/news/tom-cruise-fights-the-soap-opera-effect-for-mission-impossible-fallout-blu...
i always use use my Apple TV 4 connected to hdmi/arc
Tektek12
Hi I normally have standard for motionflow but noticed after update that its using smooth. So basically they are the same setting. Its annoying as the soap opera effect is awful! I am using true cinema for now but it's quite stuttery. Hoping for a fix soon!
romeo_kii
hiya i use true motion too, cant see any stutter , but i always keep fim mode off , now that causes stutter loll
hitta_jonte
Why is film mode bad? I use true motion Smooth becuase i like it.
Tektek12
Thanks for the tip
