5 Year Warranty Question.
Drex69
I have just purchased a Sony Tv from an online retailer, which says, it comes with a 5 year warranty.
There was nothing on my invoice mentioning this, so I rang them up, and they said :
"we have registed the serial number of your tv with Sony, for the 5 year warranty"
Does this sound correct ?
And is there, anyway of checking this ?
Thanks.
EdwinaU
Moderator
Hi Drex,
Welcome to the community! If you contact Customer Support they should be able to advise you about this. You can reach them here: http://bit.ly/2mpk3fQ.
Hope this helps,
EdwinaU
Drex69
Ok, will contact Sony.
Thanks for the response.
