BBC iPlayer
claredrews
BBC iPlayer
Always been able to access and play programmes from bbciplayer  on my Sony tv but for the past 2 weeks I have been unable to play any programmes from this app.  The app is there, programmes are shown but every time I click play, the programme continually starts and stops and then buffers. So annoying. Checked all connections, even did a factory reset but still nio joy! Can anyone out there advice?
30 REPLIES 30
claredrews
@AstroSmurf wrote:
you have a green button on controller. this activates bbc iplayer
I usually go in through the menu and select the app. Is this a different way ?
AstroSmurf
Using green button when watching a programme activates bbc player so you can view that programme from the start. If your tv is 2016 model it can do this
AstroSmurf
you must be on a bbc channel for this to function
AstroSmurf
and try switching to beta version
claredrews
What is the beta vesion? Whats the difference?
claredrews
Sorry, yes I get that now. The label at the top right of the screent to "watch from the beginning".
AstroSmurf
Beta version just experimental for bbc. I think it was created for 4k compatability
claredrews
Still stopping, starting and constantly buffering..
AstroSmurf
:thinking:
claredrews
I Know !!! Short of throwing the telly out of the window, I don't know what to do! Thanks anyway.
