itv1 and last watched isn’t working on my itv hub. When I click into channels and itv1 it says I need to enter a post code, however it still doesn’t work after I have entered it. I’ve tried the ‘clear cache’ and ‘clear data’ technique but it still doesn’t work.
Does anyone have any other ideas?
many thanks
Solved! Go to Solution.
Thanks again for your reply. I’m in England. Just did a factory reset and that appears to have fixed it for now.
@sonyprobs wrote:Hi,
many thanks
You need to have tuned in channel 3 in the YouView tuning process before the itv Hub will work.
Have you done this?
Thank you for your reply. I’ve done this but unfortunately still doesn’t work 😕
You aren’t in Scotland, where you need to use the STV player, by any chance, are you?
