KD-43X8307C WiFi stopped working.
My Sony Bravia TV has just started dropping WiFi connection in the last few days. There is not a problem with my WiFi, ISP, Router or other connected devices. All of the online information on how to fix the problem has been tried several times. The router has been reset, the connection tested, the television reset and restarted. Nothing works. It is not viable for me to hardwire the TV, thats why I bought a WiFi enabled TV.
The network is always available as shown on the TV, the TV just can't seem to hold the connection.  I can connect, I get the 'connected successfully' message then after 30 seconds it drops again.  It is not a problem with my WiFi.
I've had it since 05/05/2016 and it has worked perfectly up to two days ago.
Any ideas?
Hi there
Considering that its been 10 days since you posted this - are you still having a problem.
If so, can you try setting a manual (static) IP address for the TV and using Googles DNS servers of 8.8.8.8 and 8.8.4.4 and see if that helps?
