KD 43XD 8088
stannis38
KD 43XD 8088
Does anyone know how to turn-off the trailer channel of the above TV Set. Thank you, S. Annison
4 REPLIES 4
Hi there
I dont understand what you mean by 'trailer channel'?
stannis38
The trailers begin as soon as I switch on the TV, and they go when the top box becomes active. The trailers are Google excerpts being advertised for rental purposes.
Regards,
S. Annison .
PS I will try a suggestion made.
stannis38
Good news! I have disabled the Google streaming channel by going to settings - appts - Google play - disable.
My thanks to all who contributed to the solution.
Regards,
S. Annison.
Jecht_Sin
Enthusiast
Regards,
S. Annison.
I believe you mean Google Movie/Disable. i wouldn't really suggest to disable Google Play. :slight_smile:
