Hi- I am having an issue when setting the colour saturation level on this TV. I set it to an acceptable level and return backto watching TV, as sson as I change channel, the colour saturation appears to default to a level 10-15% above the level I have just set. It is almost as if it is defaulting to 'retail' mode.
The TV is running android nougat.
I have found a previous thread that reported the same issue with this TV running marshmallow.
https://community.sony.co.uk/t5/android-tv/kd-43xd8305-software-bug-in-colour-settings/td-p/2247024
Is anybody experiencing this problem? Or knows of a fix?
Solved! Go to Solution.
Hi there
I havent seen this reported in awhile, however I can see its clearly still an issue. I have added this to the bugs and issues list and have reported it to Sony.
https://community.sony.co.uk/t5/android-tv/android-tv-bugs-and-issues/m-p/2361196#M21200
Hi Quinnicus,
Thanks for the reply. Are you aware if there was a fix for the earlier instances of this issue? Thanks.
Hi there
I am not aware of any fix or resolution for the previous issue. My assumption is that this was never resolved.
