KD49XF7596 FW version 6.6545 apparently poor WiFi performance via Internet browsers
ksaro1
I am finding that when viewing streaming content via either the Sony-supplied Internet browser or the Puffin TV  browser, that there is a constant pausing of the stream. The pausing is so constant and consistent that it makes viewing impossible. If I use another device connected via WiFi and an Internet browser I get a consistently smooth video stream. Also, if I use a video streaming app on the TV that the video stream is smooth as well. It is only when using a browser-only stream that I see this issue.
Pascale_F
Moderator
Hi ksaro1,
I'll see if I can track down an answer for you. Maybe someone else in the community has an idea in the meantime though.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Ksaro1,
As far as I am aware, the browser on the TV is not really made for streaming.
Cheers,
The_Black_Rose
