I've recently bought a 49x8305c TV. Very pleased with it and getting my head around most things now. One quick question - what program do most people use for plauing video files on a USB? I download a fair bit of stuff and play it through the TV so want something that's easy to use.
So far I've tried the native Video app, which doesn't seem to have many features, as well as VLC which seems a bit slow and clunky and KODI which seems the best so far. But I want to make sure I'm not missing out on anything.
I used to have an LG TV, in which the USB displayed as an input and you could just browse it and play the videos without a choice of which app, so going to an app first then finding the files (sidenote, why are all usb sticks called the same thing?) is a new process.
Just want to make sure I'm making the most of this!! Thanks.
Solved! Go to Solution.
Hi there
Kodi seems to be the popular choice at the moment.
That's good then, as long as I'm not missing out on anything!
Frustratingly odd that the TV doesn't see a USB as an input mind you!
my KDL43W809C is the worst for USB use i have ever seen including 3 previous Sony tv's.
this needs to improve massively and be stable treat usb as an input too as mentioned
For the 1st time ever I have considered ditching Sony for another TV manufacturer.
the USB video use is obviously not the only reason but a contributing factor, maybe the straw that broke the camels back.
I use NAS drives connected to my router and wireless to the TV. I have 2 and have had minimal problems. Those minor problems were the NAS related not the TV. The advantage of using a NAS is that your media content is available to the PC, TV, and BLU RAY player from the same device and any other device capable of being networked including KODI, VLC, Andriod TV BOX etc.
Couldn’t they just make the video app a lot better. Really simple things Sony!!!!!
Folders
alphabetical order
Thumbnails or list
aspect ratio - 16:9, 4:3
resolution - 1920x1980, 1280x720
time length - 1:12:15 or 2h 43m
Thank you so much for sharing!
3 years on and Sony has not improved their TVs.
