Ps 4 don't work
Ps 4 don't work
Ps 4 nu mai functioneaza, lumina de la controler palpaie de 10-15 ori si nu se intapla nimic, timp in care nici ps4 nu reactioneaza.
Am cablurile bagate bine, am incercat sa-l pornesc de la ambele buntoane (de pe controller si ps) si nu se aprinde.
Stie cineva cauza ?
stormyuk
This forum is for Android TV models. However it looks like the PS4 controller is somehow not paired with the PS4 anymore. Try plugging a USB cable from the controller port directly to the PS4 USB port on the front and then try and power up the controller. If you press the power button on the PS4 directly, does it start up? It could be a faulty controller or PS4 if my advice above does not work try contacting Sony over at http://support.playstation.com/s/contact-support Thanks,
