Retaining favourites as default channel mode
profile.country.SE.title
Ovle47
TV Model Sony KD 43X85
I want to set my favorite channel list as the default input when starting the TV, ie when you press the TV button on the remote control, the favorite list is always selected by default. Obviously, this feature does not exist in Sony TV:s in Sweden which is very remarkable. According to me, it would be easy to solve the problem with a software function specifying which TV channel input should be the default and connecting this information to the TV Button on the remote control.
My TV software is updated to the latest software PKG6.3800.047. The channel list has been downloaded from Com Hem to USB stick with Sony Channel Editor and downloaded to TV which worked well. The program function "Edit Channel List" in the TV is blocked and cannot be used.
SkyNet404
Specialist
Hey,
Well since I'm not quite sure about your exact question/issue, here's my best interpretation for it :
If you wanna set a favourite channel, I'd recommend checking this:
https://helpguide.sony.net/tv/iaep1/v1/en/01-03_11.html?hl=favourites
Also, it seems that you've been using the channel editor, but you're facing issues with it, so also check this one:
https://www.sony.co.uk/electronics/support/articles/00198697
Cheers.
