Sony Smart TV compatibility
profile.country.IE.title
Bernie1
Hi,can anybody tell me If S ony Portable Bluetooth Speaker SRS XB30 is compatible with my 2016 Sony Smart TV? I.e is it possible to connect wirelessly via Bluetooth? I've got a Bose Soundwave IIII and unable to make Bluetooth connection.
Would really appreciate a reply to my post.
Thank You
8 REPLIES 8
profile.country.HR.title
kinggo01
No. The TV is missing A2DP BT profile so no audio over BT.
Bernie1
Thank you very much for your reply to my query.Perhaps you could suggest a
solution? Is there a device available on the market that could solve this
issue?
Many Thanks
kinggo01
unless you really need it to be BT you can use 3.5mm-3.5mm cable.
Or look for some BT transmitter. I have zero experience with those but I believe that there are some that can be used for that.
Bernie1
Thanks for taking the time out to reply.If anyone in the community has
wirelessly connected this device to their Sony Android T.V,i'd love to hear
from them.
Bernie1
from them.
Marino.Manolo
Genius
I'm sorry but I don't understand Bernie1, you were answered... You cannot use your BT device with the TV.
Manolo
Bernie1
I was simply asking if any member could recommend a Bluetooth device or
transmitter which would allow TV and portable speaker to pair.
Marino.Manolo
Genius
Ok, now it's clear... :yahoo:
Manolo
