When I click on tv I get hdmi 1. but not the tv app
i know I have done something wrong so how do I back my tv? Currently I have to click the button that shows the programs to get into the tv
help, please
Solved! Go to Solution.
Hi @Ei9hk36 You can assign any input to the TV button on the remote in the settings. You need to change it back to TV. It is difficult to help with specific settings as it depends on your TV and software level but it should be easy to find.
Click on Settings/Watching TV/TV button shortcut/.....Now you can either choose Digital LiveTV&Catch up which is the app OR Digital which is just your aerial...you currently have it set to HDMI 1
Hope this helps, please mark as solved if it works and give me some Kudos.
Thanks😋👍
My query was about the tv APP and not about the tv button. Please help if you can.
Hi Ei9hk36, could you provide the model number of your TV? Also, do you mean the LiveTV&Catch up ? Or something else?
