X94j stuck pixel
D-Law81
X94j stuck pixel
Hi just had my x94j replaced about 2 weeks ago and have noticed a stuck pixel. Any way to fix this..? 🤔
D-Law81
Thanks for your reply, I have spoken to sony and they advised the same thing. But it didn't work, so told sony and there going to replace it as only had 3 weeks..
Piscie
Community Team
Hello @D-Law81,
Try to unplug the power as well as any external device connected, then replug and check again. Also, make sure that your TV software is up to date.
D-Law81
Hey there,
Glad that they're gonna replace it for you, but since it's only 3 weeks you can also check what your retailer got to say if it's still within return period.
Cheers.
