When using the Netflix app the TV does not change to hdr automatically Even though I’ve set IT to auto in settings. No hdr logo in picture setting either. Any tricks? Dolby vision works flawless (and is stunning!!). If I want hdr I need to set hdr mode to hdr in picture settings. Will factory reset (in picture setting screen??) likely fix this or are there other tricks?
Hi @CONKEY1, welcome to the Community.
I'm not sure there are any settings for Netflix HDR; it either works (if the content is broadcast in HDR) or it doesn't (for example if you haven't set the TV to 'Auto' in settings).
Is there a reason why you don't think HDR is working?
Mick
Thanks for reply. I both see the difference between hdr and no hdr, but also I check that there is no hdr logo in picture setting screen. This is with movies/shows konen to be in hdr. When I play hdr games through ps4/hdmi hdr comes on automatically. It’s only an issue in Netflix app as far as I can tell. Dolby vision works (99 % of the times).
