FDR AX700 counter
Philphoto
FDR AX700 counter
Is there any way of running a counter on the AX700 to show timing when filming. I could on my AX53 but can't work out how to do so on the AX700.
Tags (2)
IamNic
Hello @Philphoto,
do you mean the operation time counter: http://helpguide.sony.net/cam/1710/v1/en/contents/TP0001492482.html
- Nic
Philphoto
Thanks, Nic - but no, on the AX53 there is the option for TC, UB or counter display. The counter display simply shows on the LCD screen the length of time filming for each clip then reverts of zero. I can't see an option for counter display on the LCD screen in the menu for the AX700, unless I missing something.
