Can the HX60 send a live display to a field monitor along an HDMI cable?
djones123
Can someone please tell me whether the Sony DSC HX60 camera will work with a field monitor connected to its HDMI output port. In particular I would really like to know
1) what exactly the camera can output along an HDMI cable for live display on a field monitor - e.g. just the info that's coming into its lens, or everything that's shown on its LCD screen including the HUD information?
2) whether it can send to a field monitor BOTH when it is recording AND when it is switched on but not recording
Note: I have not got a TV set or a smartphone and so I cannot check by connecting the camera to one of these devices. I would like to buy a field monitor but first I need to know whether this camera can actually send a live display to a field monitor or not.
Sean_Mc
Moderator
Hi and welcome to the forum,
We'll check this and let you know what we find out. Hopefully, some members of the forum will also have some advice for you.
Best wishes,
Ed
Almou_10
Specialist
Hi djones123,
I think it should work as it works when connected to a TV, It will output almost everything that appears on the screen of the camera including the menu and the shooting settings.
Hope this helps,
Almou_10
