DSC WX350 zoom lever not working
profile.country.IE.title
cracail
Zoom lever stopped working. Lever moves freely but zoom does not function. Camera lens stuck on WA, otherwise working OK. Is it easy to open up and fiddle?  Thanks, Paul
Tags (2)
Hi Paul,
It might be best to contact Sony support here.
Let us know how you get on.
Best wishes,
M
8 REPLIES 8
Hi Paul,
Best wishes,
M
damonstuart
Did you get this fixed at all? I am having the same problem.
damonstuart
Joe_Dohn
Specialist
@damonstuart Have you tried reaching out to the Sony support reps? Most likely, it'll need repair.
damonstuart
Waiting for reply from Sony Support. Thanks.
Will let you know when reply comes.
damonstuart
Contacted Sony who gave this reply and it worked for me.
Resets the product to the default settings. Even if you perform [Setting Reset], the recorded images are retained.
  1. MENU
    (Setup) → [Setting Reset] → desired setting.
Menu item details
Camera Settings Reset:
Initializes the main shooting settings to the default settings.
Initialize:
Initializes all the settings to the default settings.
Note
  • Be sure not to eject the battery pack while resetting.
Joe_Dohn
Specialist
Glad to hear it was solved!
Thanks a lot for taking the time to share an update, do mark your last post as the solution so others can find it easily.
- JD
damonstuart
Don't know how to mark it as solved, sorry.
