I cant preview the images in wx100
KasunV
I have a wx100 and when I try to see the images that taken before using the play button it doesn't display the images. It keep displaing "Accessing..." on the screen.
Any ideas how to fix this?
Message was edited by: KasunV
Tags (1)
blaireau_photo
Hello KasunV - Welcome to the Sony Forums :slight_smile:
To see if there is anything wrong with the memory card itself, have you tried removing it from the camera and then inserting it into a USB memory card reader on your computer. If you do not have a reader available, most larger supermarkets and photography shops have kiosks available where you can insert the memory card and see your prints on screen.
Thanks,
Simon
