Play memories Home crashes "Browser" stopped
profile.country.fr_FR.title
perdi13
Hello
I have installed Play memories Home on a PC Vista.
When I launch it, i have on error message :
"Browser a cessé de fonctionner"
and the program closes itself.
Help ! Thank you
PS :
Message was edited by: perdi13
16 REPLIES 16
Mookster
iCloud can still run on your PC, just remove any "Apple" pictures from all the folders that are being used by PlayMemories Home. I used to integrate camera and iPod pictures of the same event into the same folder, now I can't. Perhaps I will go back to Picasa as a photo management tool. Sony should have figured this out a long time ago!!
brumul
I have the same problem and despite putting all Sony pics in a seperate folder the browser crashes. I DO NOT plan to remove all apple apps fom the computer but have found the Windows Live Photo Gallery to do a very good job at downloading pics from both the iPhone and my Sony cam and a very good job at editing. Until Sony fixes this very buggy application I will pass on it. They make a good camera but BAD applications. Try Windows Live Photo Gallery or even Picasa as a fine alternative :wink:
lahudso66
I have upgraded from Windows 7 to Windows 10 - now my copy of Play Memories Home will not load
My present camera is Sony DSC - HX50V
Jonnie1266
@lahudso66
Hi, may I direct you to here
This thread will lead you to the Sony Windows 10 evaluation checks page - PlayMemories Home has not been evaluated for Windows 10 yet.
Regards
If it ain't broke don't fix it
Palazzo13
Hi, Im getting a browser error when I attempt to import Media files from my HX400V on Win 10. The referenced page says my camera is compatible (which it is as I was able to copy pics in Mass Stirage mode as a workaround)
Popup for MS Visual C++ Runtime Library
Runtime Error!
Program: C...
R6025
- pure virtual function call
Running Windows 10 Home 64 bit and PM Home 5.0.01.09090.
I've created a PM Home environment check CAB file - who should I send it to?
dsc-hx60v
Play Memories Home (latest version) crashes when trying to import image from my dsc-hx60v photocamera. I get an error saying Browser stopped and the program stops completely. I run PMH on windows 7, 64 bit and i have the latest firmware. Reinstall did not make any difference.
Anyone for a solution or another option.    ????
I have the same issues , I bought my Sony cybershot 4 years ago,  I upgraded my pc , had to re install Playmemories now it crashes every time i try to do anything , please help
if you can provide a link to update , it would be appreciated , thank you
mick
[edited for privacy]
