bdv-ef200 multi region code please
littlejohnblue
how do i set the multi-region on my bdv-ef200, does anyone knopw....help
Bravia55HX
simply put, you cant!,
all blu ray decks are region locked, the only thing you can do is unlock the dvd playback to multi-region but that usually requires the deck to be sent away to be done, and truthfully not worth the effort.
to recap- only DVD playback can be multi-region playback NOT blu ray discs.
Bravia55HX
