Solved! Go to Solution.
Hi there
In turns of audio wattage output, your older DZ260 is 850w and the BDV-E190 is 300w. Sony release a range of models to suit individual needs and budgets. I will say though that the BDV-E190 is now a discontinued model. Have you considered Sony's new range of Blu-ray based home entertainment systems.
BDV-E2100 - 800w (£229.00 on Amazon)
http://www.sony.co.uk/product/hch-systems-with-blu-ray-disc/bdv-e2100
http://www.amazon.co.uk/Sony-BDVE2100-Blu-ray-Cinema-System/dp/B00BJG656C/
I understand that it is approx £80 more than what you were anticipating. But....Do it once, Do it Right. Im just giving you an alternative viewpoint. Continue your research, to ensure that you get the product that matches your needs and budget.
Hope that helps.
Hi there
Hope that helps.
Many thanks for your input... so it seems I was looking at a lesser model, I presumed that because it was a similar price to what I paid for my existing model that it was a similar model.
As I mentioned I am very pleased with the performance of my existing model so I want something which is compariable in terms of power, I had overlooked the BDV-E190 but it looks to be exactly what I need!
Many thanks,
John.
