For some reason in the last few days the program numbers on the Guideplus listing do not hold. All the digital channels (apart from those set to external receiver) revert to whatever is the last channel that has been selected when you do a manual change in the Editor sub menu. The TV is a Sony Bravia KDL-40W55XX & the DVD Recorder is a Sony HXD1095, and the set top box is a Virgin Pace unit set to Eurosport host channel 521. Everything was working fine until about a week ago but for some inexpliciable reason it will just not hold the program number whatever sequencing I try.
The Guideplus website seems to be none existant.
Anybody got any ideas to overcome this problem.
Solved! Go to Solution.
Hi petecossie,
welcome to Questions & Answers..:smileyhappy:
Does anything in the KB below help..
What has happened ?
For more information please click this link Guideplus website
Are Sony products affected?
YES are affected : Sony model number type RDR-HXD which have the Analogue Guideplus feature. Analogue and Digital Sony recorders some of the RDR-HXD (e.g RDR--HXD870)
Guideplus will no longer operate on these products but there is an option to now use the Sony Guide which is similar to Guideplus but can only be used with Freeview transmissions. Another option is that if you subscribe to SKY and to the UK Eurosport channel you also have the option of using Eurosport as the HOST channel. Details on how to use Eurosport as a HOST channel can be found within the rercorder's supplied instruction manual.
These models have never had the ability to provide Analogue Guideplus but the customer does have the option to use the Digital Guideplus system.
Hi petecossie,
What has happened ?
