MY HOME CINEMA DOESNT RECOGNISE GREEK SUBS FROM USB STICK
profile.country.el_GR.title
gkants
HI I HAVE A SONY DAV-F300 HOME CINEMA.IT DOESN'T PLAY GREEK SUBTITLES WHEN I PUT AN USB STICK.HOW CAN I UPDATE IT?
Bravia55HX
no Sony devices will play subtitles from usb drives, and i assume you are trying to watch a movie with the greek .srt file?, if that is the case try something like AVIAddXSubs software and hard code the subs using that.
Bravia55HX
amk786
well ... by hard code you mean updating the software code for subtitles? http://imagicon.info/cat/12-13/licklips.gif
“Life’s tragedy is that we get old too soon and wise too late.”
