HI I HAVE A SONY DAV-F300 HOME CINEMA.IT DOESN'T PLAY GREEK SUBTITLES WHEN I PUT AN USB STICK.HOW CAN I UPDATE IT?
Solved! Go to Solution.
no Sony devices will play subtitles from usb drives, and i assume you are trying to watch a movie with the greek .srt file?, if that is the case try something like AVIAddXSubs software and hard code the subs using that.
well ... by hard code you mean updating the software code for subtitles?
