NSZ-GS7 Volume Control
Drumlad
Getting more and more familiar with this great box.
One thing I'm interested in finding out more on is if there's any way to control the outputting volume on the NSZ-GS7 itself rather than using the volume rocker on the NSZ remote, which is controlling the TV.
Thanks in advance for any advice
gofrost
no there is'nt no point as you only want to change audio level when you are listening or watching something you can configure the device to control an av receiver
gofrost
garlangreeny
I've been looking for such function and just to know that it is not possible. Thanks for your answer.
