i have just purchased the blue ray player bdp
-S1100 i am trying to connect it to the internet with a ethernet cable as per instructions but it keeps coming up physical connection ok internet access failed any body got any suggestions i would be gratefull for any help as i am not very I T orientated thank you TOMMY
Solved! Go to Solution.
Hi there
Select Setup from the home menu and goto Easy Network Settings and follow the on screen instruction. I cant remember what they are, but choose auto for everything. If it mentions DHCP choose that.
Cheers.
