sound levels
dave22122
sound levels
on my STR-DH 820 the rear speakers output more volume than the front and center speakers. i have manually educed the rear speakers to -0db and uped the front and center speakers is there any way this problem can be fixed?
Bravia55HX
assuming you  used the microphone when you performed the set up you should not be experiencing this excessive output from the rear surrounds, if you have moved this or changed speakers you may need to go through the set up process again.
