deep Sleep and phone app
visol28
my phone seems not go in deep sleep mode.the awake time is too much
the phone app is draining battery more than screen.factory reset didn't help and I don't know which app cause that problem.
it really bother me.
profile.country.RO.title
_alexdon_
Remove clean master,battery doctor,you do not need them.
alexdon
20 REPLIES 20
_alexdon_
visol28
Can you explain more..
How long should I Run my phone in safe mode??!
_alexdon_
As long as you need to see if there is any difference.
alexdon
visol28
If the problem solved in safe mode what should I do?
What if not?
_alexdon_
If not solved,we should try a software repair.
alexdon
visol28
Thank,you
_alexdon_
How do we stand?Solved or not?
alexdon
visol28
No i don't how I figure out wherevthe problem when i put my phon in safe mode
_alexdon_
You have to see if the same battery drainage occurs in safe mode.
alexdon
