deep Sleep and phone app
visol28
my phone seems not go in deep sleep mode.the awake time is too much
the phone app is draining battery more than screen.factory reset didn't help and I don't know which app cause that problem.
it really bother me.
20 REPLIES 20
visol28
Ok i go it
This problem usually cause,after each phone call
profile.country.RO.title
_alexdon_
See if in safe mode,the same drainage occurs.Maybe it is an app related to this.If not helping,just use sony update service and repair software:
http://www.sonymobile.com/gb/tools/update-service/
alexdon
visol28
the problem solved in safe mode
how should i recognize the program which cause this problem??
_alexdon_
It might be a task killer,battery saver,antivirus.What have you installed lately?
alexdon
visol28
clean master - es explorer - viber - whatsapp - battery doctor
no antivirus
_alexdon_
Remove clean master,battery doctor,you do not need them.
alexdon
visol28
no task killer need?
what about ES explorer?
I've read somewhere that prevents deep sleep
_alexdon_
Could be,but first remove the task killer.
alexdon
krixus25
the app i download is not working, but i can still see in my apps
krixus25
i really need help all the apps in my phone is not working, BBM, WHATSAPP. i mean all including the new once
