I apologise if I have missed the answer in the exisiting discussion, but I would like to edit the dictionary on my Xperia Arc (LT15i). I have only just disabled 'learn words' and have a too many wrongly spelt words in the dictionary for my first few months with the phone.
Any advice/guidance would be appreciated
Solved! Go to Solution.
You can't edit and remove words selectively but if you wish to remove them, you will have to remove em all
Settings > applications > manage applications > all > International keyboard > clear data
Thanks Nabeel for the advice.
Being a novice, how do I restore the factory default dictionary after I have cleared the data?
By clearing data your dictionary will automatically restore itslef to default settings..
May i know what you want ?
Thank you Nabeel, you're a star!
I was frustrated with a series of incorrectly spelt words that I had not spotted in my texts, I know that I should always check before pressing send, but sometimes I was a little trigger happy!
All back to normal now - thanks.
I thought that as it was called a smartphone their must be a way of removing the rubbish inputted by the user without having to delete the entire memory (as I saw in one discussion, but not for the ARC)
Thanks again - one novice user
