How to change the length of the ringtone before the call is send to VM
Uliwooly
1) *#61# in the dial pad
this will then bring up a number and how long your ring time is write down the number you'll need it later
2) on the dial pad again type this
**61*(put the number you written down before here e.g. 07923874658)*11*(how long u want it to ring for before voicemail e.g. 30 for 30 seconds)#
so it should look like this **61*07923874658*11*30#
3) exit everything, back to the dial pad, dial  *#61# just to double check that it worked
19 REPLIES 19
Uliwooly
up
Uliwooly
up
Uliwooly
up
Don't understand the posts you have made, ie up, up, up.
Have you edited the initial post and hence wanted to let other people know? Slightly_smiling_Face
Uliwooly
I had some PMs asking about this, just trying to bump it up
Ok  Got it, Was wondering why you keep replying to yourself with up in other post also.
Uliwooly
this is another way to do it
**61*121*11*30#
still can't get this done, though i've tried your sequence of #s*s and numbers, but i think the problem might be that i don't have a data plan. anything i can do to change the number of ring through the hookup to my computer?
the limit its pre-set by your network, the option above work if your network hasn't limit this to 10seconds or 15seconds. the maximum limit is 30seconds
