Hi would be very grateful for your advice. Just purchased the KDL32CX523BU and I've tried to attach my HDD which is a Western Digital 160Gb WD1600U017-004. The TV didn't recognise the HDD so I reformatted it twice, once as NTFS and once as exFAT. But neither has worked so I was wondering if anyone had any advice on how to get the TV to recognise the HDD? Many thanks. Nick
ps I've also tried the HDD diagnostic but again the TV says it's not detecting it (although I get a message when I plug in the usb that the TV detects the presence of an HDD!). Confusing! Thanks.
Message was edited by: tvprob
Solved! Go to Solution.
Hi, thanks for the suggestion. I've reformatted as FAT32 using the GUI here http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm but it still isn't being recognised. Any other suggestions?
Many thanks
Nick
Hi again,
my guess is that the drive is not powered by its own power soarce and its likely thats why its not working properly, not all USB ports carry the power required for this.
Sony recommend the western digital my book essentials which is a powered drive and despite this recommendation theres a conflict of information as to what will or will not work with Sony tv's.
i believe Sony should post a sticky on here regarding this issue and be more direct with what exactly the requirements are in terms of HDD's for the use on their tv's.
Thanks again, Bravia, that does seem feasible. And yes it sounds as though Sony need to provide more info!
Best wishes
Nick
