KDL32W653 TV iPlayer issues
Whenever I try to watch something on iPlayer it runs OK for a little while and then goes blank.  Once this happens there seems to be no way of recovering it, I just have to turn off the TV and then turn it on again.
What's more, if I try to watch the same programme multiple times it seems to get a little further each time before blacking out again.  iPlayer works OK on my upstairs TV (also a Bravia but slightly older model) and also on laptops etc.
Has anyone else experienced this?
Hi there
Try going onto a BBC channel (ie BBC 1) and pressing the Red Button.  The BBC have launched a new service, called the Connected Red Button, and are currently trialing it for your model (as another option other than the app route)
More information : HERE
4 REPLIES 4
joburdo
Getting very similar problems for the last couple of weeks.
TV Model 32EX503
Software PKG4.117EUL-0108
I've done a factory reset and refreshed the internet content but still cutting out about 10 times in a one hour programme.
It's not the connection as all the other internet content is working fine e.g. 5 On Demand, YouTube.
Has some one done a software update at Sony or the BBC and not tested it very well?
Looking forward to an improvement!
Jayess51
I have recently purchased the same model and am having the same problem with BBC iplayer.  Have tried resetting to factory defaults and refreshing internet connection.  No improvement.  I also recently lost the BBC iplayer icon on applications and had to reset to factory defaults.
Hi there
Jayess51
Thank you this works sometimes so is better than nothing! Subtitles were missing from a program that did play but tried another and they were there? Iplayer app has disappeared again. It is a shame because this TV was more expensive than other models because of it's internet capabilties.
