Obtaining the MAC Address for router access
phitangu3
How do I find the MAC address for my Sony KDL-37EX503 or the UWA-BR100 dongle as I need this to allow my router to accept the device as that is part of my security set up?
Tags (2)
Catmambo
No need to register to get the mac address - just go into the network settings area on the TV and it will be listed there. Otherwise simply temporarily turn off your MAC authentication on your router and connect the TV. Your router should normally then display the MAC address of all devices connected right.
4 REPLIES 4
profile.country.da_DK.title
kristiansenz
Go to the Sony : internet.sony.tv - register your TV and you will see your TV MAC address.:smileyhappy:
phitangu3
I have registered my product with Sony Europe.  I cant see any internet.tv link on that site  Do I have to register it again with the US one to get access to this information?
Catmambo
phitangu3
Thanks.  That worked a treat.  I had already turned off the access control to get the access, but didn't think to look at the station list to see the MAC addresses connected.  Doh!  Thanks again.
