Hi, Im looking to buy a Blu-Ray player with wireless and the Sony BDP-S790 looks pretty impressive. The only problem seems to be the TV catch-up offering. It seems it does have BBC Iplayer, but does it also have 4OD & ITV Iplayer aswell like the Samsung BD-F6500?
Solved! Go to Solution.
@huxley123 wrote:
BBC iPlayer isn't working at the monent, it's been broken for over a day.
On the off chance that you have not noticed Sony have posted the following in another thread on this subject -
@StartTheCar wrote:
Afternoon.
My colleagues in the Product Quality and Engineering team picked this up yesterday and are now looking into it.
As soon as I hear more I will let you know.
Lee.
The post above can be viewed in the following thread - BBC iPlayer no longer loading on BRAVIA TV (Dec 2013)
might be worth bookmarking that thread so you can keep an eye out for further updates..:smileywink:
Hi there
If the specs dont mention it, therefore its not supported. ITV Player and 4OD are not supported.
@StartTheCar wrote:
Afternoon.
Lee.
