Hello all,
I am looking at upgrading the 80GB 4200rpm hard drive that came with my A197XP and wondered if anyone knows of a maximum drive size that the BIOS will accomodate.
The main reason for the upgrade is that the supplied drive is just too slow for my needs. I do have a spare 60GB 7200rpm Hitachi drive, but am a little unsure if it's a good idea to put that one in due to the heat it pumps out.
I've seen a Seagate 100GB 5400rpm drive which should fit my needs, but don't want to buy one if it wont work!
Thanks for any help.
Cheers,
Ben
The BIOS is new, so I suspect it'll handle 100GB
Thanks for the info.
Seb,
Maybe a request to the VAIO Link team?
They send you a password after the username.
I have a username, a password and I can logon.
But no e-support.
Only the possibility to register my notebook.
Strange
I have registers my Notebook.
(after two years:smileyraised_eyebrow: )
A small window tell me that Sony first was checked my registration:smileyraised_eyebrow:
And I must wait about 24 hours.
what a confused VAIO-world:smileyrolling_eyes:
