A197XP Hard Drive
cyberhounds
A197XP Hard Drive
Hello all,
I am looking at upgrading the 80GB 4200rpm hard drive that came with my A197XP and wondered if anyone knows of a maximum drive size that the BIOS will accomodate.
The main reason for the upgrade is that the supplied drive is just too slow for my needs. I do have a spare 60GB 7200rpm Hitachi drive, but am a little unsure if it's a good idea to put that one in due to the heat it pumps out.
I've seen a Seagate 100GB 5400rpm drive which should fit my needs, but don't want to buy one if it wont work!
Thanks for any help.
Cheers,
Ben
20 REPLIES 20
profile.country.de_DE.title
seb21__
 Its important if you need support anytime.
That's a good point, but.........
........An error occurred while processing your request.
Please try again.
what is that??
Any Ideas?
