AR11M Vista Problem with Net
logan76
Hi.
i lost my ethernet conection when i lock_unlock windows vista
Dekesh
not sure if its set up like this in vista but i will give you an xp method that might help.
go to start>connect to>show all connections (its probably the network connections in the vista control panel).
from the list of network connections check if the ethernet (usually described as Local Area Connection) is enabled. if it already is then maybe you can try disabling and re-enabling the connection. hope this helps
vlad177
Same problem, FE41ZR, Vista, wireless network adapter disconnects after lock/unlock. Though network adapter via TP cable working properly.
FE41ZR wireless adapter disconnects after lock/unlock
tonybeard
Another trick is to turn off and turn on the switch on the chassis
