Bios Update ??? DRINGEND
profile.country.de_DE.title
tobiasxyz
Hallo comunity wie es einigen schon bekannt ist habe ich das vgn-nw21mf und suche ein Bios update da man mit meiner jetzigen version so gut wie garnichts konfigurieren kann bis auch die boot fähigen laufwerke.
ich habe im moment version R1120Y4.
schonmal danke :wink:
5 REPLIES 5
tobiasxyz
kann mir da denn niemand weiterhelfen ?
dartrax
Vielleicht solltest du hier besser englisch schreiben :wink:
He has a VGN-nw21mf and is searching for a bios update, because with his current version he can't configure anything but the boot drives.
His current version is R1120Y4.
He likes to thank you in advance.
- dartrax
profile.country.ro_RO.title
essentzza
I have a problem with a Vaio NW21MF and don`t find nowhere bios software to writte the Bios. I did search on the web and lista all sites of service laptop and don`t find any answer. Does any one knows how can i find bios for this model ? thanks.
essentzza
P.S I forgot to say, my laptop doesn`t work and i can`t make update from Windows .
rich912
Hi essentzza,
As far as I can see there is no BIOS update available from Sony for this model and installing any third party BIOS could very well brick the machine. If there was an upgrade available it would be an .exe run under Windows, so no use to you anyway.
As the machine will not boot (work) why do you think that a BIOS update will solve the problem?
If you provide more details of the problem we may possibly be able to advise further...
Rich
Go n-éirí an bóthar leat
