My camera just show very dark picture (shadow) e.g. when using with Skype.
Any suggestions to rectify the problem would be appreciated.
Is it possible to reinstall the camera software/driver?
Thanks very much.
Ali
Solved! Go to Solution.
Hi Ali,
Your model uses native windows drivers for the camera so re-installing as such from Sony Support is not an option. You can remove the camera from Device Manager, shutdown, reboot and let Windows re-install the drivers automatically, but I doubt somehow that this will have any effect.
If it is only Skype that is giving the problem then try re-installing the software.
Rich
Hi Ali,
Rich
