First of all, thanks for the help, and please forgive me about my english (I'm spanish speaker). Well, the problem is this:
Yesterday, I played with my brother at the notebook, an he was playing with 'alt' and 'ctrl', and, as you know, the 'FN' button is in the middle. Well, after played, I rebooted my pc, and got into linux, and worked well. But, when I came into windows again, I saw that the bloq_num is activated (only in windows).
So the problem is that the Bloq num has been activated by a sequence of pulsations, thus I've to press FN to write a simple 'o'.
Does anyone know a method to deactivate bloq_num in windows?
THANKS!!!
If you turn off number lock next time you're in Windows and shut down it should remember to keep it off
Ok, but how can I do that? I mean, how do I turn it off?
Hi mick16_alvaro,
Just press the number lock key, should be 4th button in on the top right of your keyboard, next to the F12 key.
